Hello,
I'm having some issues tracking down all of these vacuum lines, I just have three of them left - or at least I think I have just three left...
I've labeled my pictures with the following information: Green are fuel lines and Red is vacuum lines. Any help/ideas/corrections are greatly appreciated.
Green
1 - fuel from tank
2 - return line to tank
3 - evaporate line from tank (bottom port on charcoal canister)
Red
1 - port on carburetor - connected to #13 Electrovalve
2 - port on carburetor - connected to #9 (middle port on charcoal canister)
3 - port on carburetor - connected to #10 (top port on charcoal canister)
4 - port on throttle body - connected to #8
5 - port on throttle body - connects to ??
6 - 'T' shaped port on intake manifold - one side connected to brake master cylinder, the other to #12 (Electrovalve)
7 - 'F' shaped port on intake manifold - one port goes to #15 - the other - connects to ??
8 - ERG valve - connected to #4
9 - middle port on charcoal canister - connected to #2
10 - top port on charcoal canister - connected to #3
11 - port on bottom of air cleaner next to crankcase breather hose - connects to ??
12 - Electrovalve - connected to #6
13 - Electrovalve - connected to #1
14 - 'F' shaped port on intake manifold - capped to itself
15 - connected to #7
16 - connected to #17
17 - connected to #16
'76 vacuum lines
'76 vacuum lines
'76 Fiat 124 Spider - Padrona
