34 adf on 1800 manifold Help
1979 Fiat Spider. Hi I just received my 1800 intake from Autoricambi. I know that I have to remove the 2000 intake and the emissions stuff, and bolt on the 34 adf carb on the 1800. That's easy. My question is what kind of issues I will run into as far the vacuum advance, and carb idle and mixture. I mean, is it just a straight bolt on, turn the key and off I go or do I have to do something else to make it work right? Thanks
Roberto
1970 Oldsmobile Cutlass Convertible
2005 Toyota ECHO
2007 Honda Pilot
2005 Toyota ECHO
2007 Honda Pilot
Re: 34 adf on 1800 manifold Help
First question...
Where did you get the carb?
That will make all the difference as to how much you have to do to it. In other words, did you buy it freshly rebuilt from a mechanic who was prepping it for a fiat spider with the same basic engine specs as yours? If not, you should assume that some adjustment will be required.
Brand new from Mr. Fiat. Thanks
Roberto
2005 Toyota ECHO
2007 Honda Pilot
2005 Toyota ECHO
2007 Honda Pilot
That's great!! You may be good to go!
I may be wrong but doesn't the 34 have a vac advance outlet?
Yes, I think so
Roberto
2005 Toyota ECHO
2007 Honda Pilot
2005 Toyota ECHO
2007 Honda Pilot
Actually I am not sure. Anybody knows if the 34 ADF comes with vacuum advance port?
Roberto
2005 Toyota ECHO
2007 Honda Pilot
2005 Toyota ECHO
2007 Honda Pilot
Some do, some don't. I have one without it. I plan to just swap out the ignition with one of marks units with a mechanical advance. Problem solved but will cost you. The other option is to drill the port yourself. I've seen some instructions on how to do this doesn't seem to be a difficult process.cyberborikua wrote:Actually I am not sure. Anybody knows if the 34 ADF comes with vacuum advance port?
