New Fuel Tank
dmg36054
New Fuel Tank
Post by dmg36054 »
Well, after moving to a new city and taking a new job, I've finally started to work on the spider. The old fuel tank was rusty, varnishy (yep, that's a word), and full of gunk. Fuel pump didn't pump. Sad fuel lines. I have new components ready to go in. I received a new tank from one of our most cherished vendors today, and noticed that it already has a small amount of rust on the interior surfaces. Not much, but some.
Is it common for a new tank to have a little rust? Should I go ahead and plan to seal it first? Let her rip like it is? Get a replacement?
Dennis
1981 Fiat Spider
4uall
Re: New Fuel Tank
Post by 4uall »
I would contact one of our most cherished vendors to see what they say :wink:
AriK
Re: New Fuel Tank
Post by AriK »
Someone else had this issue a while back and it had a happy ending. I'm sure the cherished vendor will resolve this with a smile :wink:
dmg36054
Re: New Fuel Tank
Post by dmg36054 »
After receiving an email from the vendor, it looks like I either install it as is or seal it myself. There's only a small amount of surface rust in the tank, and that is common according to the vendor. I don't want it to get worse, so I'll be sealing it. Not too big of a deal, since the tank is relatively inexpensive. It could be worse; new tanks could not be available at all.
Dennis
1981 Fiat Spider
azruss
Re: New Fuel Tank
Post by azruss »
my new tank had some very minor surface rust in random locations inside the tank. I've had no issues with it
DanD
Your car is a: 1972 Fiat 124 spider
Re: New Fuel Tank
Post by DanD »
http://www.amazon.com/s/?ie=UTF8&keywor ... phydlni6_b
I have been very happy with this sealant in the past. However, fuel stabilizer and conditioner on a regular basis is probably just fine.
76was124
Patron 2019
Patron 2019
Re: New Fuel Tank
Post by 76was124 »
See the pictures of my similar experience in particular the weld seam. http://fiatspider.com/f08/viewtopic.php?f=30&t=28609
Not sure if we share the same cherrished vendor, or if your rust was that severe, but you can pm me if your curious.
Current 81 Spider 2000
Previous 76 Spider
dmg36054
Re: New Fuel Tank
Post by dmg36054 »
Update: The cherished vendor called me this afternoon and we had a nice conversation. As we would expect, they are stepping up to the issue and making it good. Now I need to order a few more parts. Life is good.
Dennis
1981 Fiat Spider
spider2081
Patron 2024
Patron 2024
Re: New Fuel Tank
Post by spider2081 »
Wouldn't fuel in the tank stop the rust with out sealing?? My experience has been no car that I drive has had a tank rust through from the inside out. I have only seen real damaging rust in cars I purchased that sat for years with a partial filled tank.
I believe the most common cause of rust on original Fiat tanks is from the outside. They rust where the foam sealer is between the tank and the trunk floor. I pull the tank on every Spider I refurbish and treat this area.
