Heater Fresh Air Flap
v6spider
Post by v6spider »
Curious if anyone had ever made their own fresh air flap out of stainless. I'm thinking about making one..
Thanks! :)
Rob
http://www.v6spider.com
baltobernie
Re: Heater Fresh Air Flap
Post by baltobernie »
Why? It is invisible once the cowl is installed. Clean up the OE flap and paint it.
v6spider
Post by v6spider »
baltobernie wrote:Why? It is invisible once the cowl is installed. Clean up the OE flap and paint it.
It is totally rusted beyond repair.. I've looked at it.. It's very simple I could make one out of stainless and it would never rust again.. Just curious if someone else has done it..:)
Rob
burgandy81
Your car is a: 1981 FIAT Spider 2000
Post by burgandy81 »
Hey Rob,
This is going back a long way!!!
How did you resolve this? I am in the same spot now and am just starting to mock up the replacement.
Google shows me that the original flap is concave and recessed down into the vent intake when shut. I assume this helps with sealing when closed? Possibly increases negative pressure and helps seal when moving?!??
Anyway, at best, my flap will be a flat piece of sheet metal.
What did you do?
Thanks,
Jordan
124JOE
Post by 124JOE »
you should paint it with por 15 if you are using just metal
v6spider
Post by v6spider »
burgandy81 wrote:Hey Rob,
What did you do?
Thanks,
Jordan
Haven't done anything yet.. I'm basically running with out it at the moment.. But it is on the list if stuff that I want to fix.. And yes I think a flat piece of metal will work fine..
Rob
