So I replaced my brake pads last week, and finished off by bleeding the lines. All seemed fine until I got to everything sealed back up, and fluid was leaking where the brake line enters the caliper on the front passenger side.
The lines are roughly 3 yrs old, and are braided steel lines. There is a thin brass washer that goes on top of the fitting at the end of the line, and another that goes underneath, between the fitting and the caliper itself. This is the case on all 4 wheels. There was no leakage before I took them apart, and none of the other three leak after being put back together.
I took the front passenger side line off the caliper again, and visually inspected everything. I don't know for sure what everything is supposed to look like, so I don't know if it looks like it should. The lower washer seems very smooth on one side, and slightly ridged on the other. The ridged side appears to match what I see on the fitting at the end of the brake line - slightly ridged. The ridges are concentric around the hole, not running across the metal. I don't know if this is a/the problem or not.
If anyone has any insight, I'd be happy to hear it.
Thanks,
-- se
Breaks leaking fluid where line enters caliper
- fiasco
- Your car is a: 1969 Fiat Spider
Steve Eubanks
Re: Breaks leaking fluid where line enters caliper
Most people replace the washers, but you can reuse them if you heat them with a propane torch and let them cool. Some people also sand them slightly with fine sandpaper on a flat surface..
- Your car is a: 1979 Fiat 124 Spider
Did you disconnect the brake line while changing pads? I've never had to do that. If so, then yeah, I would replace the washers.
I ordered these washers from Amazon, and they work fine, available on prime!: washers
--John
2007 Audi A4
2007 Audi A4
- fiasco
Yeah - I took the calipers off when I changed the pads. I wanted to clean and inspect everything, and it was just easier to get the pistons pushed back in on the workbench.
I went ahead and sanded the one washer till it was nice and smooth on both sides, then reinstalled. No leaks and the brake pedal is nice and firm now.
Thanks for the help.
-- se
-- se
Steve Eubanks
