Vacuum advance on FI distributor
Just noticed (because hidden by air intake from afm) that there is no vacuum advance hose on my dist. I have electronic ignition, so should I plug it up. If not, where does vacuum line goes to on engine.
Re: Vacuum advance on FI distributor
check out this photo. you can see my blue hose running from the distributor. It connects on the interior side of the intake plenum
Somewhere under the throttle drum. It may be disconnected because the vacuum advance is broken. Connect a hose to it and try sucking or blowing through. If you can, then the diaphragm is broken inside, and if you connect it to the intake it will be like a small unfiltered vacuum leak.
Found it and attached the hose, must have accidentally knocked it off when I was installing coolant T @ heater hoses. Frustrations ended, car running well.
Thanks all
Thanks all
