This is why I haven't given my car an Italian name, I don't know any good Italian curse words.
I never had to remove the drive shaft to do that. Just use a 1/4" socket set with a u-joint and some extensions.DanD wrote:Pop out the driveshaft, and above it is a little plate on the transmission held in place with three little nuts. Above that plate is the loose nut you seek.
