fitting chrome rings / bezels on the instruments
cos
Your car is a: 1978 cs2 spider
Post by cos »
Not sure if this has been covered before, but i just documented my attempt to fit these chrome rings to my spiders clocks.
I've heard that there are 2 designs available, one is the replacement type and the other is bezels that go over the existing rings. Now the original black rings are made of aluminium and are easy to remove as well as fit on the clocks, but the ones that i bought from evilbay in Germany we made out of stainless. And here is a big problem. It's almost impossible to fold the edges neatly no matter what. The ultimate solution is to have a special press tool made, but it will be cheaper to buy another car instead.
there were no instruction with my kit and I've read somewhere that bonding is one solution, but when fitted to the panel, the clamps at the rear pull the clocks tight against the rings and i wandering how long before the bonding gives way.
My solution was this: mask the new chrome rings neatly all round up the fold line.
Then using a dremel or similar tool remove the excess material but leave 3-4 bend tags.
De-burr any sharp edges, re-polish the edge and then place a few layers of masking tape to avoid any damage to the chrome surface.
Removing the old aluminium ring is very easy, using a small screwdriver.
Clean the instruments and glass
then with all cleaned parts assembled (ensure you don't get any finger marks on the glass!) time to fit the new rings and bend the tags.
one finished, 5 more to go!
the finished assembly. While i was at it, i replaced all the bulbs just in case.
divace73
Re: fitting chrome rings / bezels on the instruments
Post by divace73 »
many thanks for posting that, that is a good idea, I have those rings as well and was thinking how I going to acheieve the same thing
Cheers David
see my >>You tube channel<<
4uall
Post by 4uall »
Bookmarked :wink: Just awesome, thanks
cos
Post by cos »
i was hoping it will be of help.
Forgot to post the photo of best way to remove old std aluminium rings:
new ring with tags looks like this assembled
the Clock assembly is a bit more troublesome as the time adjuster keeps the glass and a few other parts located through a hole, and needs a bit of patience
btoran
Your car is a: 1975 Fiat 124 Sport Spider
Post by btoran »
very nice solution. mine wasn't nearly as elegant.
http://www.fiatspider.com/f08/viewtopic ... el#p200308
1975 Fiat 124 Spider
htchevyii
Patron 2022
Patron 2022
Post by htchevyii »
Looks good, I used the chromed plastic covers and just silicones them over the stock ones.
Trey
Your car is a: 76 124 Spider
Post by 76124 »
I used silicone on mine 20 years ago and have not had a single issue. Mine are the replacement steel or brass can't recall type. Paid way too much for them at Bayless back in the day.
Kraig
Everett, WA
76 Spider owned just shy 30 yrs and counting
69 Spider - Big truck ate it :cry:
74 Sedan special TC Auto..Died of cancer RIP
paulwall
Your car is a: fiat spider 1977
Post by paulwall »
fitted chrome rings to my gauges a little time a go ordered from Germany but never got them? they sent to wrong address? as look would have it I saw a set for a morgan car on ebay and took a punt on them..hay presto! they fit like a glove complete with little tags that just folded over. they cost only £10 good result after that prob.with Germany..paul
cos
Post by cos »
send us the link!
