Misaligned fingers on pressure plate
BNelsonAz
Post by BNelsonAz »
Putting the motor back in my son's 1980 FI Spider and noticed that the fingers on the pressure plate are misaligned. New pressure plate recommended or just bend them back in place?
DanD
Your car is a: 1972 Fiat 124 spider
Re: Misaligned fingers on pressure plate
Post by DanD »
My guess is that when it is bolted in place they will even out.
you can't just bend the fingers, that is a diaphragm spring that is heat treated. If the fingers are misaligned with the pressure plate bolted to the flywheel, it needs to be replaced or rebuilt. That spring can crack or deform
