What I learned while cutting the rear springs
bran100
Your car is a: 1982 Spider
Post by bran100 »
Cut 1 1/2 coils from the rear today. Amazed at how easy that was.
  • With all 4 wheels on the ground, I unbolted the top of the shock.
  • Jacked up one side of the rear with a jack under the lower shock mount
  • Placed a jack stand in the standard jack location
  • Loosen the e-brake adjustment nut completely
  • Remove tire
  • Lower the jack completely, watching the brake lines to insure there's no tension
  • Unbolt the lower shock mount
  • Wiggle spring and shock out very easily
  • When replacing, leave the shock tension strap in place, but replace the rubber bushing at the top
  • Slide spring and shock in place insuring spring mounting cups are rotated appropriately
  • Install lower shock bolt
  • Jack up the assembly using the lower shock mount as the jacking point
  • Cut the shock tension strap
  • Install top mounting washer, bushing and nuts
  • Install tire
  • adjust the e-brake
  • Remove jack stands
  • Lower jack completely
Probably less than an hour per side. Unfortunately it's raining so I'm not inclined to drive it today. Next, I need to cut another 1/2 coil from the front to level it out.
BellaMachina604
Re: What I learned while cutting the rear springs
Post by BellaMachina604 »
Here's what I learned cutting the rear springs 1 1/2 coils:
1) Jacked up the car with rear wheel removed
2) Used outboard spring compressor to compress the spring
3) Cut the coil off with a small grinder, 1/2 coil at a time; removed coil pieces
4) Moved bottom spring mount around until it matched bottom of spring
5) Loosened compressor until spring seated into lower mount
6) Mounted wheel; lowered jack
7) Repeated other side
Took 15 mins per side, no need to remove shock or spring from car.
pchdesign
Post by pchdesign »
I'm going to be cutting my coils here within the next couple of weeks but I haven't really looked at them. Is it obvious which end to cut? Top or bottom?
thanks.
brackie1
Your car is a: 1978 124 spider
Post by brackie1 »
I lowered my car by putting the car on a rack and heating the coils and while hot and soft was able to pull the car down in small increments until I got it where I wanted it. Lowered it 1 1/2". Worked great.
Gene
North Carolina
DieselSpider
Post by DieselSpider »
There is always the option of just using lowering clamps to see if this is really what you want.
About $12 a set for lowering 2 springs so $24 to lower the whole car and it can be undone, fine tuned, etc.
https://www.pepboys.com/product/details/1054873/01447
Nanonevol
Post by Nanonevol »
Good idea! I never heard of that. Looks like a lot less work also. I suppose I'd still need a spring compressor?
1977 Fiat Spider
1985 Jaguar XJ6
1966 BSA Lightning
brackie1
Post by brackie1 »
actually once the springs have cooled they will stay in place. you will have to put the car on a lift so that you can easily get to the springs. you can use the spring compressor to bring it down once the coil has softened. I learned the trick from a friend who builds race cars. But once it's done its done.
Gene
North Carolina
you have the possibility of the spring breaking at the spot it was heated.
DieselSpider
Or just put a bag of sand in the trunk to one side and jack up that wheel installing the clamps when the spring is compressed enough.
RRoller123
Post by RRoller123 »
I think Mark is right. If you heat spring material to the point of softness, you change the composition by driving alloying elements out of the heated area, most likely increasing the brittleness of the spring a great deal.
RRoller123
double posted for some reason
Nanonevol
Post by Nanonevol »
Thank you Diesel. This is sounding like an easier and cheaper project than ever.
1977 Fiat Spider
1985 Jaguar XJ6
1966 BSA Lightning
brackie1
Post by brackie1 »
I guess all of that is true but it has been 6 months and 6,000 miles and still good.
Gene
North Carolina
DieselSpider
brackie1 wrote:I guess all of that is true but it has been 6 months and 6,000 miles and still good.
Some get away with it while others don't so it can be luck of the draw. Do you feel lucky? In truth it can also be due to how you have the flame on the torch set as too much oxygen can leave things more brittle than a slightly richer mix.
PMcG
Post by PMcG »
Learning how to cut the spring is interesting but what happens to the handling of the car if you lower the back by one and a half coils. Where does the roll centre go?
