Intermitten temp gauge
- red107
- Contact:
I was driving my car the and notice the temp gauge would peg out. After a few moment it would return to operating temp. Do you think I'm looking at a bad ground, sending unit, or faulty gauge? I know the car wasn't over heating. I pulled over and everything seemed normal. The fan does kit on and off normally. I do have a infrared thermometer but it was at the house. Any ideas?
1981 Fiat Spider 2000
2015 Ram Eco Diesel 4X4 Laramie
2018 Jeep Wrangler JLU
Re: Intermitten temp gauge
Probably a bad connection at the sensor on the top of the head at the rear, the one that pegs the needle in an actual overheat situation. The front one sends the proportional resistive temp reading to the gauge, the rear one just pegs it above a certain point.
- focodave
Not trying to be "that guy", but it is actually the front (between plugs 1 and 2) sending unit that pegs the gauge in an overheat situation.RRoller123 wrote:Probably a bad connection at the sensor on the top of the head at the rear, the one that pegs the needle in an actual overheat situation. The front one sends the proportional resistive temp reading to the gauge, the rear one just pegs it above a certain point.
The rear one (between plugs 2 and 3) is the one that operates the gauge under normal temp conditions.
1970 MGB GT (my other hobby)
OHHHHHHHH YOU ARE SO "THAT" GUY
All kidding aside this might help
http://www.international-auto.com/videos.cfm
- red107
- Contact:
Thanks guys!!!
- azruss
this is classic symptoms of a sticky thermostat. does the light go on when the gage is pegged.
- red107
- Contact:
I can't remember if the light came on or not. I will check again this weekend.
There is no light.
- red107
- Contact:
I believe I found the problem. G3 the ground above the ignition switch. I will find out after a test drive. Still nice weather here in Eastern Carolina for top down driving.
