"Test Pipe" Performance Improvements?
RRoller123
Post by RRoller123 »
Has anyone replaced their catalytic converter with a "test pipe", 8) and can you describe any performance improvements or other changes in engine behavior? Assuming all other systems are functioning nominally, do you get any real gain in performance by doing this?
Thanks for sharing any info on this!
Pete
81SPIDERMATT
Re: "Test Pipe" Performance Improvements?
Post by 81SPIDERMATT »
mine seemed peppier ... but I also increased air flow and put on a better muffler (or so I was told) at the same time I deleted my cat .... I have heard it is a cheap and effective way to get a little extra juice
RRoller123
That's what I was thinking too. Really easy, so if it makes a significant difference it makes sense.
Anyone else?
joelittel
Post by joelittel »
Mine felt a little peppier too. I noticed a more sporty feel to my acceleration as soon as I opened it up. It's not going to blow your doors off, but it will be more fun to drive.
toyfiats
Post by toyfiats »
RRoller123 wrote:Has anyone replaced their catalytic converter with a "test pipe", 8) and can you describe any performance improvements or other changes in engine behavior? Assuming all other systems are functioning nominally, do you get any real gain in performance by doing this?
Pete
The difference between the USA-spec FI Spiders (102hp) and the Euro-spec Pininfarina Spiders (105hp) is only 3hp, with the main difference between the two systems being that the euro cars did not come with a catalytic converter. Assuming yours is still functioning and isn't plugged at all (if its original that's doubtful) you'll gain all of 3hp at the most. It will certainly sound different, but I doubt anyone can feel that small of a real performance difference.
RRoller123
Thanks for the info! It also weighs a lot more than the pipe and the cat support system rattles at ~4500-5000 rpms, which drives me crazy. I think it is going. My MA insp people never look for it. But I will save it in the attic just in case....
narfire
Post by narfire »
I didn't notice any difference really after swapping out the cat. I did notice a difference after spending a ton of $$ on the engine though.
donm
Your car is a: 1980 spider [carb]
Post by donm »
I had my cat replaced by a muffler shop a few years ago when I bought the car because the welds were broken and it was leaking. The guy pointed out to me the difference between the old style cats like our cars had and the newer style which is more of a flow though design.
The newer style is a honeycomb design and is much less restrictive. I decided to go with it so it wouldn't be a potential reason to flunk my car during the yearly inspections we have here. If the car came with one, technically it must be present or they can flunk you. And also, just in case at some point in the future MA might require emission inspections even for older cars like ours.
1979 Spider
2001Saab SW
2004 Saab Aero
TX82FIAT
Post by TX82FIAT »
As others have pointed out the old CAT's have a shelf live and often become partially restricted so it feels like the gains are substantial when you put a test pipe on. New CATs are much better. With that said, i took mine off and have a straight back 2.25 system with a resonator and a muffler (no CAT). I think the exhast being opened up with the larger pipes gave me about 5 - 7 hp. I can't really tell because I changed a bunch of things at once.
82 Fiat Spider 2000
03 BMW M3
07 Chevy Suburban
redcars
Post by redcars »
On my FI 82 I replaced my newer high flow cat with a 2" test pipe. The exhaust is stock front with assa center and rear mufflers. I did not notice any difference in performance. I you want an improvement from exhaust go with a 2.25" system all the way. Don't expect much more that a 5% increase without other work.
1987 Lotus Super 7 clone
1981 Fiat Spider 2000 AT
1982 Fiat Spider 2000 5sd
1970 Fiat Coupe
RRoller123
Thanks for all the info, folks.
DanD
Your car is a: 1972 Fiat 124 spider
Post by DanD »
I think you would find that all the improvement is in the last 500 RPMs to redline. It doesn't make much difference until you are pushing a lot of flow, and at that time, you will see an improvement.
RRoller123
Thanks, not the way I drive it, so I will leave the Cat in. I don't believe it is blocked. But I will get the DAMNED RATTLES out of the support system fer sher... :evil:
bobplyler
Patron 2022
Patron 2022
Post by bobplyler »
I put one in when the car was about 1-2 years old. Didn't notice any real performance difference, but the cat rattle stopped.
1979 Fiat Spider (since new)
1999 Honda Shadow VLX 600
RRoller123
I pull away from my favorite Friday night cruise, where the American iron actually loves my Spider and I get many complements and have great friends and conversations! I show it off, run it up through 2nd and 3rd from the stop light at the end of the driveway, and it does that damned noise at about 4500-5000 and I am totally embarrassed. :? LOL :mrgreen: One way or the other, it must stop.
