driveshaft question
- Your car is a: 124 spider
driveshaft question
Wondering are our driveshafts hollow and are they suppose to rattle when shook? I have a 78 spider many thanks
Re: driveshaft question
Yes they are hollow and no they should not rattle. Is the rattle from in side the drive shaft?
1987 Lotus Super 7 clone
1981 Fiat Spider 2000 AT
1982 Fiat Spider 2000 5sd
1970 Fiat Coupe
1970 Fiat Coupe
Yes inside thats what im suspect my vibration is coming from
hollow for sure, if that puppy was solid it would take a forklift to move it
Is there any visible damage? Dented? Bad u-joints and rotted rubber in the carrier bearing are the typical causes of vibration but if is damaged it will likely be out of balance.
im in the process of rebuilding it i will rebalance after im done and go from there
