My '73 suffered some minor rear-end damage in her past, and when I got the car, the trunk was heavily soiled. Lid gasket OK. One obvious leak was around the tail lamps; the gasket didn't fill the void between housing and body. The fuel tank was dented and didn't fit too well; fixed that. But there are other areas where I can "see the light"
There's only one hole plug present. Should the other openings in the trunk be sealed? (there was a bird's nest in the one above) How about the wells on either side? Factory drain holes, added by you, or none?
