Came across this while searching for an O-ring for the Idle Adjustment Screw. There are a few useful tidbits in there:
http://mastertechmag.com/pdf/1988/11nov ... ronic2.pdf
btw:
Does anyone know the exact size for the O-Ring that seals the Idle Adj Screw? Or who sells it?
Thanks.
Pete
L-Jetronic Guide
L-Jetronic Guide
Re: L-Jetronic Guide
I would take the idle screw out, and either take it to home depot or a plumbing supply place. Put some rubber grease on it before you screw it in.
