15 psi radiator cap
bsharp
15 psi radiator cap
Post by bsharp »
I have a 78 fiat spider 124 and the AutoZone manual I have calls for a 15 PSI radiator cap. I can only find a 13 and a 16 psi from the parts stores. The 13 will not hold the pressure and I was wondering if the 15 psi is correct and if a 16 psi would be too much. Ant thoughts out there
azruss
Re: 15 psi radiator cap
Post by azruss »
13 psi is what is recommended. with 15 to 16, you are prone to develop leaks.
bsharp
Post by bsharp »
thanks-might try to flush --just runs hot at times
majicwrench
Post by majicwrench »
Not sure what you mean "13 won't hold the pressure" any cap will leak when it's pressure is exceeded, that's why they have an overflow tube. If you fill a system completly full of coolant, it will piss some of that out as the coolant expands. This is normal.
Pressure is essential in a system, pressure raises the boiling point, and more btus can be carried at a higher pressure.
How hot does it run??
bsharp
Post by bsharp »
about 230
MrJD
Your car is a: Looking to ask questions about a 79 2.0
Post by MrJD »
lol.. the radiator cap is not your issue. That is pretty freakin hot.
