Timing belt covers left off, any problems?
- Texsardo
- Your car is a: 1978 Fiat Spider Convertible 1800
- Contact:
OK, know you may be getting tired of my questions but?
I have noticed in several members photos of engine compartment, they do not have the ugly yellow timing belt covers installed.
Is it for show because I noticed one parts site that had colored wheels, cogs,etc. Is there any greater risk with it off? I like the
Look of the naked belt. Looks sportier. I will be replacing my belt and or parts soon. Thinking if no big problems with it off, I may leave the belt naked. Any thoughts?
Texsardo
Texsardo
- Your car is a: 79 spider
Re: Timing belt covers left off, any problems?
It's possible that something could fly up under your engine and end up in your timing belt. I'm not going to use any of the covers, but I bought a splash shield/ rock guard to close up the under side of the engine bay some
- Texsardo
- Contact:
Where did you find the splash shield. I have a 78 Spider.
Texsardo
Texsardo
you shut your mouth
i got mine from John Erskine... You should put a want add.. someone probably has one laying around...Texsardo wrote:Where did you find the splash shield. I have a 78 Spider.
Texsardo
Damn Jay.. lol...4uall wrote:you shut your mouth
- Texsardo
- Contact:
Oops, sorry, I meant visual appeal challenged. Lord, why do I put yellow at the bottom of my physically visual undesirable list, just above pink or salmon?
Texsardo
Texsardo
Juvius, you might want to consider modifying the splash shield so you can easily get at the oil filter. I suspect that this is why there are so few of them on these cars, they block easy access to the filter. I cut away a small portion and lined the sharp edge with extra gas hose slit lengthwise. A little black RTV holds the hose on the edge.
You will lose the ignition timing marks too.
1974 124 Spider
1964 500 D
2012 500 Sport
1948 Ford 8N tractor (restored (don't drink and ebay))
1964 500 D
2012 500 Sport
- hayesbd
- Your car is a: 1973 Spider
...speaking of splash shields, does anyone know if installing the splash shield cures the hood shake at highway speeds? That would be my only reason for looking to re-install one.
Thanks,
Brian
Thanks,
Brian
Current: 1973 124 Spider
Previous: 1961 600D, 1970 850 Racer, 1973 124 Special, 1974 124 Special TC
I am not sure, but I can say that I don't get any hood shake, and I have the shield installed. But I very rarely go above 60-65. Even so, smooth, no hood shake.
- kmead
The cover is unlikely to have any effect on cowl shake. It is a splash shield not a structural member.
What it can do is: minimize the amount of water that can splash up into the engine bay, ensure air flow at low speed is out behind the crossmember of the frame and the air cannot short cycle out the bottom of the car to be sucked back in the front of the car: it promotes better cooling. The later versions of the shield added a small spoiler which helped with forcing more air into the intake just above it.
Later cars added the large plastic spoiler to assist with this and reduce the amount of air going under the car creating a low pressure area under the car (which can draw more air through the engine compartment).
They were clearly put on there for good reasons that are just as valid today as they were in the 1960s when the car was engineered.
Karl
1969 Fiat 850 Sports Coupe
1970 Fiat 124 Sports Coupe
1985 Bertone X1/9
1985 Bertone X1/9
- Redline
- Your car is a: formerly a 1971 Fiat 124 BC Coupe
Thanks for that insightful post. I only got as far as "water protection" in thinking about why there is one on the Coupe.
http://www.124bc.com
- seabeelt
- Patron 2019
Pete, the bottom of your car is just way too clean
It doesn't look that nice anymore, Mike. I need to get it up on the lift and get out the black Rustoleum and a small throw away brush again. But I never drive in the rain or snow, only that one time we got caught coming back from Tutto about 2 years ago.
