Installing 32 ADFA on 1800 manifold
gmichaud
Post by gmichaud »
I am installing the rebuilt 32 ADFA on the 1800 maniofld on the 79 Fiat 2L. I want to make sure I avoid air leaks and other potential problems.
Simple questions: In what order do the carburetor base plate gasket and spacer go? Which is next to the manifold? Which is next to the carb? Should I have a gasket on either side of the spacer?
Thank you for your help?
Gil
bobplyler
Patron 2022
Patron 2022
Re: Installing 32 ADFA on 1800 manifold
Post by bobplyler »
Carb
Gasket
Spacer
Gasket
Manifold
1979 Fiat Spider (since new)
1999 Honda Shadow VLX 600
gmichaud
Post by gmichaud »
Thank you.
If I were to make my own gasket...what type of material should I use?
toplessexpat
Post by toplessexpat »
www.mirafiori.com
gmichaud
Post by gmichaud »
Thank you,
Gil
