78 fuel line check valve/regulator?
timspider
Post by timspider »
On my 78, I don't see a fuel regulator referenced in my shop manual, just a check valve on the main feed line from tank.
do I not need any kind of fuel regulator on this line?
I'm running a new facet cube, rated at 2-4 psi, at this point I have it running straight through the fuel filter with no check valve or regulator.
do I need one or the other or both or neither?
Thanks much.
timspider
Re: 78 fuel line check valve/regulator?
Post by timspider »
well this is a first.
no one has an opinion on this.
hmmmm
