hi.
i have 1979 2000cc fiat spider.
i have bought 1800 manifold with DEFV carb from here:
http://fiatspider.com/f08/viewtopic.php?f=11&t=26777
anyway, i need the manifold gasket and carb gaskets and spacer.
when i enter international-auto.com i see carb spacer of 7mm and 12mm
which spacer do i need ?
which gaskets of the carburettor do i need ?
and especially which exactly manifold gasket do i need
please try to accurate from what you see in the pictures in the link i attached
many thanks
raviv
converting 1979 2000cc to 1800 manifold & carb
- Your car is a: spider 1979 cs2
Re: converting 1979 2000cc to 1800 manifold & carb
You don't necessary need a spacer, you can replace the studs with shorter ones, which we carry.
Here's the intake manifold gasket you need:
http://www.autoricambi.us/product/GA4-4 ... arbureted/
Carburator base gasket:
http://www.autoricambi.us/product/FU1-4 ... se-Gasket/
or
http://www.autoricambi.us/product/FU1-4 ... te---45mm/
Do you know that you have to disable the EGR to make this work?
or
