steering box lube
kenmataya
Your car is a: 1972 124 spider
steering box lube
Post by kenmataya »
how often does anyone change their steering box lube? and can you do it on the car?
Thanks,
Ken
Ken
72 124 spider 1608
75 124 coupe 1756 (RIP)
72 124 coupe 1608 (RIP)
v6spider
Re: steering box lube
Post by v6spider »
My factory service manual suggests topping it off with 90wt Ep if it gets low. The unit holds 7.25 oz ... long as it had lube should be good to go.. the idler uses probably the same. Although they didn't talk about that in the manual.
Rob
http://www.v6spider.com
kenmataya
Post by kenmataya »
top it off to the brim? My Haynes manual is a bit unspecific!
Thanks,
Ken
Ken
72 124 spider 1608
TX82FIAT
Post by TX82FIAT »
I think i read on a few posts to leave to oil about 3/4 of an inch below completely full in the steering box. This seems to make sense to me.
82 Fiat Spider 2000
03 BMW M3
07 Chevy Suburban
