Can you put too much fluid in a transmission?
I bought two bottles of GL-1 from Vicks (who incidentally were the only vendor I could find who carried it) and both will fit in the transmission, although I did have the front of the car elevated above the rear.
The specs call for 1 3/4 quarts and I believe each container is a quart, although they are not marked.
Jim
Jim
Re: Can you put too much fluid in a transmission?
I don't believe that is possible
I filled mine until it trickled out the fill hole. This might help
http://forum.fiatspider.com/f08/viewtop ... ansmission
- Your car is a: 1975 Spider
if it is done, it will be a problem, too much fluid, could cause the fluid to leak from the breather and the seals
son has 78 spider
son has 78 spider
ok thanks, I'll level the car and let it drain thru the fill plug.
Cheers,
Jim
Cheers,
Jim
The next time you need GL1 give NAPA auto parts a try. I don't want to take any business away from anyone. However, you can buy it in one gallon jugs for less than your two quarts.
82 Fiat Spider 2000
03 BMW M3
07 Chevy Suburban
82 Fiat Spider 2000
03 BMW M3
07 Chevy Suburban
I did go to NAPA...in fact I tried every avenue you could imagine in Canada. Nobody has it.
Jim
Jim
- btoran
- Your car is a: 1975 Fiat 124 Sport Spider
i had to try 4 napa stores before i finally found one that had it in stock (about 40 mins away from home). the other stores were hesitant to order it because they have to order 4 gallons at a time and adide fromt he one glalon i needed, said they wouldn't be able to sell the others.
1975 Fiat 124 Spider
These guys among others have it here in Canada
http://www.driftaround.ca/collections/m ... llon-50205
Thanks Jay,
I've read lots about the various GL Grades and I figured as long as I was going to all the work of pulling the engine and trans and then having the trans professionally rebuilt I wanted to go with strictly GL-1...although I know GL-4 has been used as a substitute.
While I know it was expensive thru Vicks...especially when they said they had to have a minimum $50 order before they'd ship it to me, (and I must admit they could have stated that a bit more eloquently than the way they did), I was already so frustrated at trying to find it elsewhere.
Jim
Jim
double post?
I hear ya brother
i won't even start about Vicks
I went with this, and I have heard good things. Made an immediate difference
Yes, that one was a possibility if I absolutely couldn't get the GL-1.
But now I'm glad I went the distance and got my first choice even though it took a long time to get.
Cheers,
Jim
Cheers,
Jim
- Patron 2024
The lower plug on the passenger side of the transmission is the fill plug. I read here of more than one person over filling from the top plug.
I know I have the right plug. In fact once I leveled the car and pulled the filler plug back out I recovered a little less that 1/2 of a quart before it stopped pouring out, so that would leave 1 3/4 quarts to fill it to the fill hole which is just what the specs call for.
Cheers,
Jim
Cheers,
Jim
