Power window stuck
smokey14
Your car is a: 1983 pininfarina
Power window stuck
Post by smokey14 »
I have an 83,2000 with power windows, my passenger side window is stuck in the down position. when I use the switch to raise it the motor just clicks,anybody have any ideas on what I can do to fix the problem? Thanks!
adrians
Your car is a: 1981 Spider Turbo - missing the turbo
Re: Power window stuck
Post by adrians »
Hi,
First up, swap over the switches between the driver and passenger sides to determine if it's the switch or the motor.
I my case it was the contacts in the switch that had gone due to old age ! - Buy a new switch.
Have you checked the window regulator cable - has it been damaged or broken ?
Regards
THE FLEET
2014 Abarth "SS"
smokey14
Post by smokey14 »
I tried what you said and sure enoughthe down position was not working on one side. Thanks !
