76 ADFA Choke Pull-off Diaphragm replacement
SpiderCake
Post by SpiderCake »
Howdy all,
I'm on my second 32 ADFA rebuild, the first went smooth but the choke pull-off diaphragm that came with the rebuild kit was too small for the housing. I found a diagram with webber part numbers for the 32adfa but the diaphragm is showing as not serviceable. Image shows the size difference.
Suggestions?
Thanks,
~SC
BEEK
Your car is a: 1975 Spider
Re: 76 ADFA Choke Pull-off Diaphragm replacement
Post by BEEK »
the diaphragm you have in the picture is the power valve diaphragm from a 2000 carb, the choke pull off one has a longer shaft made into it that ll the rest of the assembly goes on, some of them come assembled.
75 spider
son has 78 spider
131
Post by 131 »
Description says ADHA, but it looks right for the ADFA.
http://www.ebay.com/itm/Choke-Pull-Off- ... de&vxp=mtr
Mick.
