Anyone know the correct size and thread for the two studs on the lower, front of the block, passenger side? I believe it was for an A/C bracket.
I pulled them out and they were extremely tight. They were 10M x 1.25. Is that the correct size?
I boogered them up removing them and now have to put a couple of bolts in because of oil leak.
Thanks in advance.
A/C bracket stud size
Re: A/C bracket stud size
Never mind all. It was 10m x 1.25 and I just sealant on correct sized bolts instead of the studs.
