crankcase ventilation filter cleaning
kenmataya
Your car is a: 1972 124 spider
Post by kenmataya »
quick question - can i pull the centrifugal screen for cleaning without removing the intake manifold? it looks like the bolt is pretty long and there's not much clearance under the intake manifold.
Thanks,
Ken
Ken
72 124 spider 1608
75 124 coupe 1756 (RIP)
72 124 coupe 1608 (RIP)
narfire
Re: crankcase ventilation filter cleaning
Post by narfire »
Once it comes out of the treaded part the bolt can tilt at a fair angle. You can take it out with the FI intake in place.
kenmataya
Post by kenmataya »
well i loosened the bolt, and now i can't get it to bite back into the threads....
Ken
72 124 spider 1608
kenmataya
Post by kenmataya »
got it reinstalled! but there was no filter inside, or gasket at the the base.
Ken
72 124 spider 1608
bradartigue
Post by bradartigue »
kenmataya wrote:got it reinstalled! but there was no filter inside, or gasket at the the base.
I know it has (or should have) a gasket, but it's a low pressure area so I doubt they leak much or at all. The design is a fluid trap (or "vapor separator"), there isn't a filter. There is supposed to be a flame trap inside the exit hose, and you can clean it with carburetor cleaner.
kenmataya
Post by kenmataya »
had a gasket from an old engine set, got it all back together. what a strange assembly, no real locator for the gasket or the cover!
Thanks,
Ken
Ken
72 124 spider 1608
