brake compensator - is it rebuildable?
- v6spider
Just wondering if the brake compensator is rebuildable or if someone has had experience rebuilding one and if it is worth the trouble. I'm getting ready to turn the car back to and upright position I want to make sure I have all bases covered before doing so..
Thanks!
Rob
Thanks!
Rob
http://www.v6spider.com
Re: brake compensator - is it rebuildable?
I am not aware that there are rebuild kits for them. A new one is ~$25, so it's hardly worth rebuilding it.
- v6spider
Oh then I should just buy a new one..which vendor?
Rob
Rob
Don't ask me, I might be biased...
You won't go wrong purchasing from Auto Ricambi
- hayesbd
- Your car is a: 1973 Spider
Another vote for Autoracambi. I bought mine from them and it's fine. Installing it, however, is another story.....
I did attempt to disassemble the old one, just out of curiosity. In a word, forgetaboutit!
Brian
Brian
Current: 1973 124 Spider
Previous: 1961 600D, 1970 850 Racer, 1973 124 Special, 1974 124 Special TC
lol good onevandor wrote:Don't ask me, I might be biased...
Jim
East Grand Forks MN
1969 124 AS Spider
2017 Abrath
2018 Alfa Romeo 4c Spider
East Grand Forks MN
1969 124 AS Spider
2017 Abrath
when installing a new one, make sure that rubber boot is in place and intact. stuff it full of grease.
Just got through installing the compensator from AR. This is a cumbersome job and I recommend taking out the right rear spring and shock before you even get started. The absolute hardest part is getting the boot on after its all together. I thought about just leaving it off, But then I would lose sleep over it thinking about all the dust and road grime getting in there. be careful not to cross thread the brake lines. The compensator is adjustable, but i just set mine to the high flow position, effectively bypassing it. Went ahead and replaced the rear center brake hose while i was at it. It took about 4 hours all in all - 2 hours of that was trying to get the boot on correctly.
- v6spider
I have given this a lot of thought. I am going to remove the stock self adjustable proportioning valve and replace it with an after market one that I will mount in the engine compartment or trunk. As it sits now the arm that attaches to the axle is directly in the way of my 2 1/2" dual exhaust pipe on the passenger side.
Rob
Rob
- Patron 2024
I purchased a parts car that had the brake line from the master cylinder rerouted (bent) back to the hose that feeds the rear axle. The fittings are identical. Others purchase a jumper hose that allows the compensator to be removed. So I think you might be ok with out a compensator.
- v6spider
It's only $35 for an adjustable one I think I'd rather have the option than not. I'm also running bigger brakes from an rx7 gsl so even more reason to have adjustability.
Rob
Rob
The entire point of the compensator is that it dynamically adjusts itself. Also, the mounting hole is slotted, so you can adjust its static position as well. Its just like an aftermarket proportioning valve, except that you get the added benefit of it adjusting itself when the weight over the rear tires is less. So, in my opinion, getting an aftermarket one would only take away from the braking performance.
- v6spider
A minor sacrifice for dual exhaust which is absolutely necessary for my engine to breath properly.
Cheers!
Rob
Cheers!
Rob
v6spider wrote:A minor sacrifice for dual exhaust which is absolutely necessary for my engine to breath properly.
Cheers!
Rob
Well that makes since then.
