Cowl drain hose
- hallgreghall
- Your car is a: 1977 Fiat
Cowl drain hose
Does anyone know where I can get the drain hose that actually goes here?
The previous owner siliconed a hose in and I would like to replace it but can't seem to find one through any of the sites online.
I like Italian food and Italian convertibles
Re: Cowl drain hose
Yes glad you posted this … I need one to don't have anything there at present but don't drive in the rain.. when washing the car I make sure I don't get water in the Cowl, pedantic about water overflow on my newly rebuilt engine.
- aj81spider
Re: Cowl drain hose
I don't think there is a hose. Neither of my cars (74 and 81) has one on either side.
A.J.
2006 Corvette
2006 Corvette
Re: Cowl drain hose
I do have both rubber hoses that go in the holes in near perfect condition. Selling for $25.00 plus shipping
http://i1018.photobucket.com/albums/af3 ... AG0399.jpg
http://i1018.photobucket.com/albums/af3 ... AG0400.jpg
- aj81spider
Re: Cowl drain hose
My bad - I guess if that's what you're referring to then my cars have them. I didn't consider that a hose - it's just a little rubber nipple that dumps into the engine compartment.
A.J.
2006 Corvette
2006 Corvette
Re: Cowl drain hose
Don't know if this is the part that you need since I only have the fische scans for a '69 spider/coupe, but if it is the same, they are here.
http://www.fiatplus.com/1968-69-cowl-dr ... 95915.html
Kevin
Kevin
Re: Cowl drain hose
Kinda makes you question the design.. None of my spiders have had those. Seems you could design something more efficient to target water to drain. I try not to drive in the rain or when there is a high probability of rain.
82 Fiat Spider 2000
03 BMW M3
07 Chevy Suburban
82 Fiat Spider 2000
03 BMW M3
07 Chevy Suburban
Re: Cowl drain hose
did he say it has it on his 69? if so i will look at mine and see if i have one, i do not recall such on the one i took apart
Jim
East Grand Forks MN
1969 124 AS Spider
2017 Abrath
2018 Alfa Romeo 4c Spider
East Grand Forks MN
1969 124 AS Spider
2017 Abrath
Re: Cowl drain hose
All Spiders have these. On earlier ones it was made mostly of rubber, which disintegrates after a while. Later they went to an all metal type, where only the ends were rubber. They ends had little flaps, likely to keep any possible engine fumes from going into the cowl and thus the passenger compartment.
- Your car is a: 1980 fiat spider 2000
Re: Cowl drain hose
Csaba,
Do you know if anyone stocks the rubber ends for the later spiders?
Boise, Idaho
1980 Spider 2000 EFI
1972 Sport Spider 850
Re: Cowl drain hose
HUH????? someone trying to scam you, ther is nothing there, it does it job by getting it out of the trough
Re: Cowl drain hose
I have not seen them, but then again I have not looked for them either.bjbrown wrote:Csaba,
Re: Cowl drain hose
vandor wrote:All Spiders have these. On earlier ones it was made mostly of rubber, which disintegrates after a while. Later they went to an all metal type, where only the ends were rubber. They ends had little flaps, likely to keep any possible engine fumes from going into the cowl and thus the passenger compartment.
Around here, they keep the mice out as well.
- hallgreghall
Re: Cowl drain hose
Lucky that is one issue I haven't had yet.
Re: Cowl drain hose
My spider (1980) didn't have anything on the cowl drain pipes at all. They just drain down past the engine/trans right at the firewall. I don't suppose that would hurt anything over the long haul...
Boise, Idaho
