The Tubing is the same diameter as the bumpershock on the outside, and is the perfect diameter for the bumperette to Barely slide into on the inside!
It is a super tight fit, especially in the back where I had to remove the edges from the bumperette mounting plate
pipe in the car
cut to rough length. I will probably drill in and use some allthread to hold the bumperette in place. Not quite decided how to secure it yet... and am open to ideas. I want it as strong as possible.
in the car
I will be welding up the extra open area here.
This will be drilled out and fit in place using the same support bolt the bumper shocks used
