hissing when turning over
rupester93
Post by rupester93 »
When starting the car and it's first turning over, a hissing noise as if pressure is escaping somewhere, any ideas? Can't locate where it is coming from. Haven't heard it while running only first turning over
narfire
Re: hissing when turning over
Post by narfire »
How are the brakes? Perhaps the diaphragm in the booster has a hole/tear. Mine had a hissing sound when the car was idling.
bradartigue
Post by bradartigue »
Loose spark plugs.
Is your air cleaner off? Carburetors hiss before the motor catches - it is always muffled by an air cleaner.
rupester93
I did just have the spark plugs out so I'll double check them.
rupester93
Located the leak, it started doing it all the time and was able to find it, an air hos e as it goes into the block is leaking, will replace it tomorrow.
