Fresh air intake under cowl
- Your car is a: 1980 FI 124 spider
Was wondering if any one resealed the fresh air intake under the cowl and what was your steps in resealing.
1980 fiat spider under restoration
Re: Fresh air intake under cowl
Do you mean resealing the body panel opening with seam sealer, or resealed the heaterbox to body connection?
- Your car is a: 1975 Spider
o do you mean the 2 fresh air intakes, many cars have those sealed off. the early spiders had closeable flaps on them
son has 78 spider
son has 78 spider
Yes the heater box under the cowl where the heater door flap is.( where the wiper motor is located)I see some heavy type of sealer around the box I was wondering if any one has removed this and resealed it or just apply fresh sealer over the old one. It looks like mine is separating from the bottom not sure if leaks water in the interior just doing a restore on the car and don't won't to find out later that water is coming in from there and not won't to remove the cowl again.
If it's separating then remove it and apply new seamsealer.
What's the best way in removing the sealer will a heat gun soften the old sealer.
