Hey guys,
At some point in the life of my spider, the lower rear shock mount broke on my 1987 Fiat Spider (Early model with the 77 Diff). The PO welded a couple pieces of scrap metal on to hold it together, and I just saw that it was broken off again.
I've got a welder who will fix it all, but I need to know of some place to get a new shock mount for them to weld on. Any ideas?
Broken Rear Shock Mount
Re: Broken Rear Shock Mount
Hey Tom
I had a critical issue with mine shortly after purchase this what I discovered
My welder was able to actually fabricate a new spring perch
The early rears are different! They have a separate piece that bolts to the bottom of the shock that has 2 studs that point
down. One bolts this onto the shock, then put it on the axle and put on 2 nuts from the bottom.
If this is welded to the rear axle the shock can not be removed again!
yup, as i said somewhere, seems that later 124's used 131 rear end. that shock mount is identical to 131
