Upgrade Exhaust to 4-2-1
tartan18
Post by tartan18 »
My car is a 1975 with the stock 1756 engine. A PO removed the cat and what is on the car now is a 4 into 1 manifold, then to a resonator and then a rear muffler.
I want to upgrade to a 4-2-1 exhaust system as I have read that will improve my engine's performance. Recently I found in a junk yard both a manifold and downpipe but now I wonder if these are the proper ones for my car. As best as I can determine, based on the part numbers stamped on the manifold and downpipe, I now wonder if these came out of a fuel injected (later model) and may not work on my car. The 4-2 manifold has a stamped number of 4462282 and the 2-1 downpipe has the number 4442168.
Here are several pictures of what I have.
What concerns me is that the downpipe outlet measures only 1.75 inch and I understand that the ideal is 2 inches.
The sound I am looking for is something "Italian" -- not the "fart" type that kids hang on their Honda Civics :roll:
Any help would be appreciated.
Jim MacKenzie
1975 Fiat Spider
4uall
Re: Upgrade Exhaust to 4-2-1
Post by 4uall »
what are you talking about? they make you look so much cooler 8)
tartan18
Post by tartan18 »
Sorry Jay ... I didn't know you owned a Civic. :oops:
Jim MacKenzie
1975 Fiat Spider
narfire
Post by narfire »
That is a 80 and later manifold, number is the same as my 80 and Jimb's 85. Six stud, no gasket required.
it should fit just fine, however the down pipe I understand is a bit longer as the 2L engines are a bit taller. I had the down pipe cut at the 2 into one and a flange welded on then 2" back.
Chris
MrJD
Your car is a: Looking to ask questions about a 79 2.0
Post by MrJD »
NO gasket? Well thats interesting.
wizard124
Post by wizard124 »
MrJD wrote:NO gasket? Well thats interesting.
I also found it odd......
So, I made one. Material bought from Napa Auto Parts. Hasn't been on too long but holding up so far:
WYSpider
Post by WYSpider »
You can us a bead of RTV Copper and be good to go.
WYSpider
Post by WYSpider »
narfire wrote:That is a 80 and later manifold, number is the same as my 80 and Jimb's 85. Six stud, no gasket required.
Can you clarify where you cut? How far after the hanger did you cut for the flange?
narfire
Post by narfire »
From the picture above, I believe it was not far from where it goes into the single, pretty much at the same spot I believe. Now you mention it, I wanted a flange but I think they just cut back and directly welded the 2" pipe to the corresponding opening dimension.
I haven't looked at it for quite some time.
If you end up taking it to a muffler place they can cut and weld, but I found they will bend the pipe(diminished inner diameter) where cut and weld direction changes is superior. (I've been told)
