Metal versus Composite Aux Shaft Gear
- spidernut
Does anyone know when Fiat switched from a metal aux shaft gear to a composite aux shaft gear? I purchased a replacement on Ebay that is metal, but it weighs about 50% more than the stock composite gear. I hadn't expected that.
John G.
1977 Spider (Sold 2017)
1979 Spider (Sold 2015)
1980 Spider (Sold in 2013)
1981 Spider (Sold in 1985)
Re: Metal versus Composite Aux Shaft Gear
Not sure about aux, but ~1977-78 is when the plastic camgears were used.
I would not worry that much about the weight, they rotate at half engine speed.
i've seen several of those plastic gears fail. go for one made out of metal
If you purchase the metal cast after market gears with 4 openings these are lighter then the solid gears.
- FiatMac
Or if you are really concerned about the weight and have the money, get the all aluminum one from Miller's Mule. http://www.millersmule.com/MillersMuleS ... ohc-engine
Stan McConnell
Retired Mechanical Engineer
Salisbury, North Carolina
82 2000 Spider (driving)
83 parts car
83 parts car
