Noisy clutch when depressed? 81 Spider
mrspahr
Post by mrspahr »
When I push down on the clutch pedal, I hear a sort of rubbing sound....not loud, but noticeable.
Makes a sheeeaaaaaa sound. When I release the clutch after shifting, noise stops.
Can someone tell me if this is normal, or do I have a problem waiting to happen?
Car is a 81 Spider FI.
Thank You, Marty
azruss
Re: Noisy clutch when depressed? 81 Spider
Post by azruss »
most likely noise from your throwout bearing. If you have a bad gearshift boot, it can allow tranny and clutch sounds to be audible. The bearing does get louder with age. Normally a pretty slow transition from good to bad.
Tobi
Post by Tobi »
My new bearing started that transition after less than a thousand miles :shock:
alsgro
Post by alsgro »
Mine is the opposite. Makes some bearing noise when the pedal is up and goes away when I depress the pedal. Been doing that for a couple of years. I think I'm going to take it to Mark soon because I also have a leaky front transmission seal. My money says he does the clutch, seal, bearing in 1 1/2 hrs flat.... F1 style.
131
Post by 131 »
alsgro wrote:Makes some bearing noise when the pedal is up and goes away when I depress the pedal.
That's more likely the gearbox input shaft bearing than the clutch throwout bearing.
Mick.
76was124
Patron 2019
Patron 2019
Post by 76was124 »
Yes, as Mick said, or the sleeve where the input shaft protrudes out of the gearbox...mine was slightly dented and caused a rock tumbler sound when pedal was up.
Current 81 Spider 2000
Previous 76 Spider
