Side Moulding
- seabeelt
- Patron 2019
Side Moulding
Anyone know where to get replacement side moulding (to prevent door dings)? I would like to match the original if possible Thanks
Re: Side Moulding
I have a fairly complete set from a 1976. I will take a look at it tonight if you are interested. I can't remember if all the pieces are there, or the condition. Call me if you want me to dig it up.
Alvon Elrod
805-338-1767
Alvon Elrod
805-338-1767
Re: Side Moulding
The best stuff is the aluminum/vinyl molding you can get from JC Whitney available in several colors (the tan vinyl matches my tan top) on my red car. The aluminum is screwed on and is very straight (measure from door bottom front and rear to have perfectly level). After door piece screwed on then use a level to set the fender pieces. Cut the vinyl pieces a little longer than needed as will shrink with time and they can be squeezed in to fit. I have used this stuff on several cars.
Warren
Sylacauga Alabama
1979 Fiat Spider Automatic
1991 Alfa Romeo Spider Veloce
1974 Dodge Dart Sport Hang 10 (in restoration)
Multiple other cars, trucks, and boats
Sylacauga Alabama
Re: Side Moulding
i believe the door side moulding was a dealer add-on "value package" item. meaning, each dealer used his own setup to install / or not install side moulding.
good luck matching yours to someone elses. ask for pictures and study carefully before you have something shipped.
