850 fuel pump replacement
patsdad
Post by patsdad »
Hello fellas
Can anyone walk me through the fuel pump replacement
Having some issues that need to be resolved quickly
I understand that its bolt on, but the new pump and adjacent part that fits into the cam etc, is leaking
any help would be appreciated thanks
patsdad
Re: 850 fuel pump replacement
Post by patsdad »
Dudes
if you can help me out please let me know
thanks, pat
djape1977
Post by djape1977 »
there's only two bolts holding it. not really complicated
SpecialTool
Post by SpecialTool »
Leaking oil or fuel?
patsdad
Post by patsdad »
Thanks for your replies
My problem is that fuel is leaking out of the pump, all over the garage floor
The adjacent tube of the fuel pump that sits in the cam cavity, not sure how its supposed to be installed
Fuel is getting through the hoses to the carb but maybe not enough or two weak of a fuel supply
pressure
any thoughts? Thanks pat
