1981 Spider
salspaugh1
1981 Spider
Post by salspaugh1 »
I'm going to repaint the timing belt plastic shroud. My question is: What is the correct factory color? The fan blades on the cooling fan are yellow. Is this correct? Should they match? I've seen yellow and gray or silver on the shroud. I appreciate the help of this forum, and I know I will get the correct answer. I used this forum many times when I was restoring the car and found it very helpfull. What is your choice for paint? I've used Eastwood spray on the dash but have not used on exterior surfaces. Appreciate your help.
Steve Alspaugh
1981 Fiat Spider 2000
2013 Honda Accord V/6 Touring
1996 Chevy Tahoe
aj81spider
Re: 1981 Spider
Post by aj81spider »
I think the gray/silver ones are metal (that's what's on my 74). They would be factory in that color. The yellow were plastic (that's what's on my 81), and would be factory in yellow color.
I used Rustoleum Sun Yellow (I got the color from a different thread I can't find) and it came out factory looking.
A.J.
2006 Corvette
salspaugh1
Re: 1981 Spider
Wow!!! that was quick. I thought that would be the answer, but you know how it is, you like to hear it from another person. Thanks for the type and color of the paint you used. That is really helpful. I will be doing some painting in the near future.
Steve A
narfire
Re: 1981 Spider
Post by narfire »
Make sure it is clean. I clean with brake cleaner and then spray a primer before the yellow. Primer I used was a sandable primer from a rattle can.
spider2081
Patron 2024
Patron 2024
Re: 1981 Spider
Post by spider2081 »
my 1980 carb car has a yellow timing belt cover
My 1981 and 82 have silver covers. I'm guessing somewhere around 8081 the color becomes silver. I would paint the cover what ever color it was.
I have painted a few fans and timing covers with good results. First I wash with gasoline to remove all oil and grease.
Then wash with hot water and TSP. The TSP does a great job of cleaning the oils out of plastic.
With spray gun spray epoxy primer then urethane color.
4uall
Re: 1981 Spider
Post by 4uall »
My 1980 FI was yellow and I too went with Sunshine Yellow Rustoleum
https://plus.google.com/photos/11828399 ... 1447288906
salspaugh1
Re: 1981 Spider
Wow!!! A lot of great information. If I mess up this job after all this information. I had better just hang it up.
Thanks.
Steve Alspaugh
