Question on the 1592 distributor position
hayesbd
Your car is a: 1973 Spider
Post by hayesbd »
I have a 132AC.040.3 in my 73. It seems to have the correct head casting numbers that correspond to this engine number as well. In fact, the whole car seems to be completely "stock" in all things. However, the odd thing is that the shop manual shows this engine with a block-mounted distributor while mine is mounted on the exhaust cam housing.
The reason I am curious about this is whether or not I have a "stock" set of cam shafts, since the exhaust cam with its distributor drive gear is needed. The Mirafiori site's table of engine models shows dramatically different cam timing amongst the various 132 types. If I ever have to service the cams, I want to be sure I know what I currently have.
Anyone else know if the '73 1592 is supposed to have a block-mounted distributor, or is my engine correct as-is?
Thanks,
Brian
Current: 1973 124 Spider
Previous: 1961 600D, 1970 850 Racer, 1973 124 Special, 1974 124 Special TC
131
Re: Question on the 1592 distributor position
Post by 131 »
There's not a huge difference in stock Fiat grinds. Advancing or retarding cam timing and using different running clearances can change characteristics, but the actual cams didn't vary greatly.
http://avs.spot-mate.com/cam.html
Mick.
