Hi,
Does anyone know of a source for pre-cut Spider trunk boards?
Thanks,
Mark
Trunk Boards
- opus10583
- Your car is a: 1978 CS1
Trunk Boards
...Yes; I know what it means: Fabbrica Italiana Automobili Torino.
DOLCETTO: 1978 CS1; 10:1, DMS, 4-2-1...
ANDIAMMO: 2012 500 ABARTH
Acquista il Biglietto; Prendere la Gita! - Hunter S. Thompson
Re: Trunk Boards
I just was cleaning out the trunk in the car I just bought and it has all the boards intact. They are not very straight, but I am going to make some templates so I can make some new ones. I believe that they are made out of 3/16th hardboard.
I will be doing this in a couple of weeks, if you are interested I can send you a template of the boards so you can make some yourself.
Gene
Gene
Re: Trunk Boards
Not too hard to do. A jigsaw is a must have.
http://www.fiatspider.com/f08/viewtopic ... 15&t=23068
Re: Trunk Boards
Generally, I would recommend that we stay away from hardboard, and use a good plywood instead. hardboard is notoriously unstable to moisture, and does not take continued stress well, hence the sagging and warpage in the oem trunk boards. I used 3/8" cherry for mine (left over from a cabinet job, so the cost was irrelevant) but anything will do. 1/4" is a little too thin, 3/4" too thick, 1/2" is ok but I had the 3/8" and I think it is optimum thickness. Rigid but light enough to easily handle. A 4x4 sheet is 54 bucks, which is ok. http://boulterplywood.com/
Old trunk boards:
New trunk boards:
Old trunk boards:
New trunk boards:
- opus10583
Re: Trunk Boards
Thanks Everyone!
I'd make them myself but; Apartment Dweller...
I've found someone who can make them up for me, and given my need think plywood is the cure: My 1100 won't fit in my 500, and is usually accompanied by half a case of shells.
Thanks again,
Mark
Thanks again,
Mark
