No spark to the coil
I was driving my 76 124 and it just died. Battery still charged,turns over but there is no juice to the coil. Can anyone let me know what it could be or where to start looking.
Re: No spark to the coil
I think the wire that feeds +12V to the coil comes directly from the ignition switch. You may have a failing switch. It is NOT fused.
Gonna have to give more detail. Did you actually check the + side of coil with a test light or voltmeter??
Keith
Keith
I actually replaced the coil. I checked with a test lightmajicwrench wrote:Gonna have to give more detail. Did you actually check the + side of coil with a test light or voltmeter??
Keith
Checked WHAT with a test light?? Which wire(s) under what conditions? Need to be detailed here. Your title says "No spark to coil" (spark doesn't GO to coil, spark comes FROM coil) and your post says "no juice to coil". Everybody loves to change their coils, but they almost never fail.
Keith
Keith
Ok I am new to the automotive repair. Took a wire directly from the positive battery post and the car started, took the wire off it died, this what I meant by no spark to the coil. Should have said no power to the coil. Does this sound like a ignition problem
The first thing that comes to mind is your ignition switch. Also look at all the connections between the ignition switch and the coil.
1987 Lotus Super 7 clone
1981 Fiat Spider 2000 AT
1982 Fiat Spider 2000 5sd
1970 Fiat Coupe
1970 Fiat Coupe
I was able to get my problem fixed. It was a wire at the ignition that had carded. Started right up. I have a weber 38/38 carb that idels well but when gradually giving gas it has a studded till more gas is given. Has anyone had this problem?
