PO Had Cowl grill issues???
LunaticTaskbar
Post by LunaticTaskbar »
Hi, I have decided to get to changing the cowl grill with a different mesh. Sadly after a lot of help from a board member the shipping for the original cowl mesh just wasnt viable.
Anyway I took it apart last night to be met with a wonderful ingenious method of application.
Now my question is this:
How do I get rid of the PO workmanship?
Contrary to how the pictures look, I do not believe that it is indeed what it looks like, ie dog poop and hay, but I think its actually Fiberglas.
Any thoughts on how to remove this endearing piece of customization?
toplessexpat
Re: PO Had Cowl grill issues???
Post by toplessexpat »
Do you want to keep the original wire or not? If not, then it looks brittle enough to pull / sand away. If you do, then have you tried alcohol? Methylated Spirits / White Spirit / Ethanol should dissolve the glues and it'll just come away. The mesh itself looks like something you could get from Home Depot...
www.mirafiori.com
BEEK
Your car is a: 1975 Spider
Post by BEEK »
the original cowl grill is a plastic piece, actually 2 of them clipped together, if you need anything im sure someone here has it as do i
75 spider
son has 78 spider
toplessexpat
BEEK wrote:the original cowl grill is a plastic piece
... an excellent point - I meant the "original from the PO" ;)
www.mirafiori.com
LunaticTaskbar
Hi all. I couldn't get back on the Forum yesterday. I stupidly changed my email and password. Which deactivated my account. It's now all good again.
I ended up literally chiseling the previous, lets call it adhesive off then made a template with cardboard. Test fitted for size made minor adjustments for the washer jets and wiper spindles. Then cut the mesh I had. I do not have the original piece. Then reassembled. IMHO it looks infinitely better than what adorned it before.
Then removed the front grill. Cleaned and painted. Re-installed.
Pictures to follow.
Ian
LunaticTaskbar
The New Cowl Grill. in the rain.
The Front grill painted.
LunaticTaskbar
toplessexpat wrote:Do you want to keep the original wire or not? If not, then it looks brittle enough to pull / sand away. If you do, then have you tried alcohol? Methylated Spirits / White Spirit / Ethanol should dissolve the glues and it'll just come away. The mesh itself looks like something you could get from Home Depot...
Hi Toplessexpat,
I did indeed try try your suggestion of alcohol, Methylated Spirits, White Spirit, Ethanol. But to be honest it wasn't as helpful as I had hoped, I just kept falling down, I couldn't see the grill, and when I accidentally did find the grill - I simply couldn't focus on it. After drinking that lot I had triple vision. :shock: :D
toplessexpat
Hi Toplessexpat,
Love it! Suggest next time not imbibing :)
www.mirafiori.com
