Paint orange gallon $200(you will need some to touch up the engine area and under hood)
Hardener for clear $50
Clear coat $120
Reducer $45
Paint suit $12
Glassfilled body filler $12
Spot body filler $8
Sand paper, tapes and razors $40
Before paint
Bumper remove, trim lights etc removal
Dent pulling and filling
Removing the vent panel in front of windshield took only 30 mins
In the paint tent
Final cleaning and lacquer thinner prep
Red base coat (free) (this was free paint I had in tent used as a primer to cover the filler). You will need to do this if you have any filler, coz all filler I've ever used can creat spiders cracks in the paint. Using actual paint as primer will guarantee you no spiders cracks when painting with the real color.
Sure enough, I had 3 spider cracks in the paint. Sanded the entire car w 600. Took 1 hour to sand the red basecoat down to smooth. Just don't focus on the rough parts and sand to smooth by hand.
Then
Orange paint (3 and half coats) and 2 coats clear (had to paint within 30 mins between coats couldn't take pics).
In two days will cut the clear and buff
