I'm Tom in Southern NH. I just got myself a spider for an incredible price. "if you can weed whack your way to it and drag it out of there you can have it" so i couldnt pass it up, he was just going to junk it. i guess ill give a little info on the car, try to post a few pictures and i definitely have a ton of questions to ask if i cant find my answers perusing the search function.
from my research, its a 1982 2000 spider turbo. i dont know much about the turbo as i can't seem to find any good information online anywhere. just that a few had them put on in new jersey when they got off the boat from italy. can anyone give me more information on these turbo cars? its not even listed as an option when i tried to find the value on nadaguides. anyone know what one of these is worth versus a regular spider 2000? all i can find thats different on this car versus other spiders ive looked at online is it has stickers in the door jam and on the cowl saying it was modified by legend industries, different wheels, and the turbo and turbo output plenum (i guess youd call it) are there in place of the usual air intake hose to the air flow sensor and air box ( so obviously it must have a different exhaust manifold too. how much did it cost new vs how much did a regular spider cost new?
its been sitting for 20 years. odometer reads 36K, the top is completely rotted to nothing and the top frame and mechanism is rusty but can be cleaned up. its bronze in color but its definitely been painted, given over spray and where its peeling of and where ive kissed it with a grinder theres a blue deeper down, but all the hard to paint parts(firewall inside trunk etc) are bronze, so maybe its the original color just been changed a few times. its a 5 speed with a tan leather interior thats actually in decent shape. its got a bit of rust here and there on it but nothing i can't handle or would make the project come to a stop. needs new rockers but the structure under the rockers looks almost perfect. any other spots can be handled with a grinder and some small pieces welded in place. also has one small hole under the back seat. all in all, body wise its better then my usual projects so im not worried about that. i plan to just pick one piece a night, do what i can to clean it up. eventually ill have it all pretty again.
so far ive power washed and vacuumed it out, threw a battery in and hotwired it just to see that things can still move. (he lost the keys years ago so ill need a new ignition switch and door and trunk locks ) and they can, with a quick shot of ether at the air box the engine will idle a bit and will run on the ether, so i know the ignition and everything is still functioning but without the ether it stops so i know its not getting any fuel. thats my main project to tackle i think to get it running. i found a good write up of tuning the l-jetronic fuel injection systems so im going to go through step by step. my main plan first, is to do a full "tune up" at least as far as i can with out it running. ill change the timing belt, oil, plugs wires, cap and rotor, change all hoses, cleaning all the electrical grounds, then ill try to make if run. this would be where i get into cleaning and testing the fuel system piece by piece. anyone have a good recommendation as to what to use to clean the fuel parts? the gas tank reeks of varnish so i know thats going to be the biggest thing i have to fight with. i figure ill start at the tank and move forward.
here's a few pics for your entertainment:
