Top Install Question
davery
Your car is a: 1985 Spider
Post by davery »
I am installing a new top on an 85 and have a quick question. On the front bow there appears to be a 1/8 inch peice of foam the runs along the front. It is glued down and has come up in parts. Does this need to come off? If so, is there something I need to put back down in place of this? The front bow seems pretty sharp along the edge that comes into contact with the top.
Don Avery
Dayton, OH/Sarasota,FL
1985 Pininfarina
2011 Eos
2012 Mercedes E550 Cabriolet
BEEK
Your car is a: 1975 Spider
Re: Top Install Question
Post by BEEK »
try and keep that piece intact, light gluing will help, it does show thru the finished product. you can replace it or repair it,
75 spider
son has 78 spider
davery
Post by davery »
BEEK wrote:try and keep that piece intact, light gluing will help, it does show thru the finished product. you can replace it or repair it,
Thanks. If I was going to replace it, is there anything I can pick up locally to use?
Don Avery
1985 Pininfarina
2011 Eos
davery
Post by davery »
The front top seal ripped in two when I took it off. I have seen OEM replacements and they seem to be pretty expensive. Has anyone used anything else?
Don Avery
1985 Pininfarina
2011 Eos
124JOE
Post by 124JOE »
go for new YOU WILL be happier in the end
BEEK
Post by BEEK »
davery wrote:The front top seal ripped in two when I took it off. I have seen OEM replacements and they seem to be pretty expensive. Has anyone used anything else?
agreed on the weatherstrip at the windshield.. new is the only way... but this is not what he is talking about. its a piece of foam, 75% of the time it has deteriorated and is gone.
75 spider
son has 78 spider
