1.8 rebuild
cp2295
1.8 rebuild
Post by cp2295 »
Hi all,
I am looking to rebuild the 1.8 that's in my '78 spider.
Can someone give me a ballpark on how much that should cost?
Thanks!
vandor
Re: 1.8 rebuild
Post by vandor »
How much of the work will you be doing yourself?
Re: 1.8 rebuild
too many variables; stock or upgrades?
narfire
Re: 1.8 rebuild
Post by narfire »
$500.00 to $5000.00 depending on what you want done and who does it....
cp2295
Re: 1.8 rebuild
Post by cp2295 »
Hi,
To start, the motor has a blown rear main seal, the clutch is fried, and the motor has 80,000 miles on it.
I have taken the motor/tranny out and need to service the head, gaskets, piston rings, things of that nature.
Any job that I can do I will do, as I am on a serious budget at the moment.
Any other specifics needed for better description, please let me know.
Does this help narrow down a price range better?
Thanks!
vandor
Re: 1.8 rebuild
Post by vandor »
If you are not replacing the pistons and will do the work yourself then all you need is a gasket set, bearings, thrust washers, and rings. However, if everything is apart you should strongly consider replacing the clutch, water pump, belts, motor mounts, freeze plugs, coolant and heater hoses. All these parts should be under $600
Oh, and check the oil pump and replace if out of spec.
