Major problem
fiat218
Major problem
Post by fiat218 »
The nut for the steering wheel is striped and can't come off. Any ideas how to cut it or any other ways, I have tried grabbing it and pullingp with a plier hoping it catch a tread, no way ,
So mybe some one can help
Thanks.
I be sitting waiting , hurry
No I did not strip it? :D California man did it
Jim
East Grand Forks MN
1969 124 AS Spider
2017 Abrath
2018 Alfa Romeo 4c Spider
azruss
Re: Major problem
Post by azruss »
my concern would be whether the threads on the column were stripped and not just the nut. you could take a small rotary file and dremel one of the edges to nothing, then split it with a cold chisel. It may be easier to split the nut with a cold chisel before grinding, so you have some meat to work with. An air chisel would make short work of it.
fiat218
Re: Major problem
Post by fiat218 »
I think the spline is ok, it just the treads on the shaft ,I'm sure there are shot and can be retreaded! I hope
Jim
East Grand Forks MN
1969 124 AS Spider
2017 Abrath
dmwhiteoak
Your car is a: 1972 Fiat 124 spider
Re: Major problem
Post by dmwhiteoak »
I actually have a socket somewhere in my box just for this problem. It's got small stainless , spring loaded pins that grab the nut while the others push up inside the socket. I don't often need it but it works well when I do. You may want to look for one. I believe mine is a craftsman. Good luck.
Dennis Modisette
1972 124 Spider
2003 Chevrolet Z71
2007 GMC Yucon
fiat218
Re: Major problem
Post by fiat218 »
dmwhiteoak wrote:I actually have a socket somewhere in my box just for this problem. It's got small stainless , spring loaded pins that grab the nut while the others push up inside the socket. I don't often need it but it works well when I do. You may want to look for one. I believe mine is a craftsman. Good luck.
Thanks, I took it over to a guy that does my work. He will get it off
He told me to sell my tools. Lol
Jim
East Grand Forks MN
1969 124 AS Spider
2017 Abrath
Re: Major problem
wanna buy a column?
fiat218
Re: Major problem
Post by fiat218 »
So Cal Mark wrote:wanna buy a column?
Might have too, I will let you know this week
Jim
East Grand Forks MN
1969 124 AS Spider
2017 Abrath
