Lexan lens rear view mirror.
wizard124
Post by wizard124 »
My inside rear view mirror was filthy on the inside, almost to the point of being useless (at night, it was useless).
So, I popped it off the windshield frame to better figure out how to tear it apart.:
For those that haven't attempted this, the outer plastic frame is snapped into position by 4 tabs, 2 upper and 2 lower. Easy to remove and can be done while still attached to the windshield frame. Unfortunately, my thumb got in the way and I broke the outer glass. :evil:
I have never tried to cut glass so I thought I would give it a go. I used an old piece of picture frame glass and etched it with a Dremel grinding wheel. Even though I had cut into the glass a pretty deep outline, when I broke it free, the cut wandered and didn't follow the trace. :evil:
I tried this one more time before giving up on this approach. The Dremel wheels erode down quickly. This attempt also resulted in a crack. I think, due to overheating the glass during the grind. Off to the hardware store. Instead of trying to find a bit to cut glass, I decided to try cutting clear plastic. I bought a small piece of non-glare plastic. It cut easily but it turned out to be opaque/blurred when used in the mirror. :evil: Trial and error.......
The 4th try was the charm :D Another trip to the hardware store. This time for clear Lexan. This is a bit thicker than the non-glare and played into the decision not to buy it the first time. :? It cut more easily. I needed to grind it a bit narrower to make it fit behind the tabs in the frame housing:
The mirror cleaned up well, showing a little patina. It snapped back together and back onto the windshield frame. Good-to-go :D
fiat218
Re: Lexan lens rear view mirror.
Post by fiat218 »
Did your mirror shake when you drove the car
Viberate in any ways? If so how did you fix it
Jim
East Grand Forks MN
1969 124 AS Spider
2017 Abrath
2018 Alfa Romeo 4c Spider
wizard124
Post by wizard124 »
No vibration..just dirty.
The picture doesn't show it but there are 2 small rubber things that seem to apply pressure to the mirror.
fiat218
Post by fiat218 »
Well one of my mirrors have that, they kinda sat on the edge. But the other 2 are not like that,but I have one with a wire like spring under the lense, that one was way differnt
Jim
East Grand Forks MN
1969 124 AS Spider
2017 Abrath
