My sun visors tent to fall when driving rather than stay up...now I can think of a few ways to fix this, but like the old clutch pedal spring with the coins trick, I will bet there is a clever fix out there. What say you blokes ???
Baz
sun visors
- Your car is a: 1985 Spider
Re: sun visors
Mine did the same thing and I tightened the screw closest to the outside of the car. Of course, that seems to be a weak spot in the design and I think it might create more stress on that spot.Baz wrote:My sun visors tent to fall when driving rather than stay up...now I can think of a few ways to fix this, but like the old clutch pedal spring with the coins trick, I will bet there is a clever fix out there. What say you blokes ???
Baz
Don Avery
Dayton, OH/Sarasota,FL
1985 Pininfarina
2011 Eos
2012 Mercedes E550 Cabriolet
1985 Pininfarina
2011 Eos
Re: sun visors
I just took mine off. Didn't really understand what sun visors did on a convertible. Haven't missed them.
- 81SPIDERMATT
Re: sun visors
i was surprised how much i liked having them gone.... it was a lot
Re: sun visors
taking them off actually improved my line of sight, especially at intersections
If you must keep them then try velcro or shrink wrap on the inserts
Re: sun visors
I took an old, flat or common screwdriver and filed a notch in the center with a flat needle file. This allows it to straddle the pin in the center of the screws on the sun visors. Tighten these screws very slowly until the visors stay where you want them.
