sodell wrote:I bought some new ones but they did not look the same as the old, so I used the old ones. I know where they go but which way do they go in?
Honestly, I don't remember! That was about 35 years ago when I re-built my '71 1608
That outcome (installing the thrust washer backwards) resulted in severe wear to the crankshaft. It was so bad, the crank moved fore/aft in its bearings and had a bad knocking.
I pulled the engine and the machinist welded up the crank end and machined it to spec.
Hopefully, someone else will steer you on the right path
